tips needed on cowl stay repair
6 posts Started 14 Sep 2012 Last recovered post 16 Sep 2012 Wayback Machine snapshot 15 Apr 2013
Well... i had a partial tip over at a gas station the bike fell against a pillar but the mirror absorbed the fall or so i thought. When i got home i found that the fairing stay was bent.
My question is, what is the best way to bend it back and is it salvageable or should i just get a new one?
My thought was to heat it up and bend it back into place. It is not very noticeable until i turn the bars all of the way to the right.
Thanks for the feedback.
Take the bodywork off the front to expose the stay, then slip a pipe over it and tweak it. Reinstall front clip to check alignment. Lather, rinse, repeat until it's fixed.
Pain in the rear, but a lot cheaper than the alternative!
No heat needed, by the way.
Thanks! I'm glad it's as simple as i thought.
Where is this cowl stay located? Just curious.
It's the metal sub frame that supports the front cowl and headlights and such. It also supports the mirror stalks. Replacements are from 120 to 170 bucks. I think i just about have this problem licked.
End of thread · 6 posts recovered Wayback Machine snapshot 15 Apr 2013
