Knight Design is now offering their footpegs for the 7th Gen VFRs. ~$135USD
www.knightdesignllc.com/index_files/Honda_VFR_G7.htm
I'd had their footpegs (2" drop and 1" drop) on other bikes and the quality and feel was superb so I reached out to them and they came through.
- 1" drop so no lower than the feeler on the stock unit.
- Articulates rearward the same with stock spring and pin
- Within adjustment range of the stock pedals (I'll still likely take out the locknut from the brake adjuster for 1cm more)
- Shift lever became 1cm closer to the left peg when I set height.
- Had the Sidetrax before but chose the Quadtrax this time. More grip and less vibration due to boots on little pyramid tips.
- Would describe the level of vibration w/o the rubber as the equal to what I feel on the bars.
Here is what they look like:
[image: post-25818-0-51519800-1347997271.jpg]
[image: post-25818-0-69007700-1347997359.jpg]
[image: post-25818-0-77615100-1347997808.jpg]
[image: post-25818-0-70764500-1347997884.jpg]
[image: post-25818-0-05664400-1347998011.jpg]
[image: post-25818-0-53880000-1347998517.jpg]
[image: post-25818-0-49763800-1347999696.jpg]
[image: post-25818-0-95056900-1347999721.jpg]
[image: post-25818-0-57344700-1347999751.jpg]
[image: post-25818-0-32624000-1347999901.jpg]
