My carbs are clean. My tank/petcock are clean. Knowing that...........
So, yesterday on my way home my '93 VFR started acting strange once warmed up. The idle starting going bad/rough at stop lights and in traffic. When I pulled away from a light or accelerated it ran as though it was starving for fuel until about 3K rpm at which point it ran fine on the highway all the way home.
This morning on my way to work same issue. Started fine. Warmed up fine. First 50 miles of my drive it was fine. Got to the gate on base and while waiting in line to get on base the idle got shitty and actually died once but started right back up. Same thing on the way home. Started fine but got the bad idle in traffic but fine above 3K rpm.
I just got home and though WTF!!!!! I tested battery voltage while bike was off and its 12.1v
While ideling the voltage is at 11.8v
At 4500-5000 rpm it read between 9 - 12v
Am I to assume my R/R or stator as craped out and I should started searching through the 100000000 posts on here about it?
