6Th Gen Custom Chain Guard Question... - Modification Questions
6 posts Started 27 Feb 2013 Last recovered post 28 Feb 2013 Wayback Machine snapshot 31 Oct 2013
Ok, I've looked at and scoured pictures and posts all over the internet, and this sight of course, and I can't seem to answer a question that popped into my head:
If I'm going to make a custom chain guard, do I need to use the two mounting holes where the plastic screw tabs go? (on the top of the SSSA)
The material is going to be stainless steel. Heavy I know, but a piece that would work was given to me for free,,,
I've seen lots of pictures of the outside of different chain guards, but never the inside. I looked on Thurn's website, and couldn't really tell. Same issue with other companies as well.
Also, I ask because I know my Katana only used 2 mounting points.
Wasn't sure if sebspeed or someone could point me in the right direction... :beer:
It's been awhile since I had my stock chain guard on, but I don't recall any mounting hardware going through the top of the SSSA.  There are a couple screws that locate the brake lines, but IIRC, the chain guard is actually mounted along the side of the swing arm.
Stock chain guards have 2 plastic screw-type clips on the top of the swing arm. I'm guessing to help support the weight/movement of the brake lines. Something I'm not too worried about with a stronger chain guard.
You can see them in this pic:
  • [image: chainguard.jpg]
Edited by 91talon, 28 February 2013 - 06:23 AM.
No you don't need to use them. The stock guard only uses them, because its a heavy piece of plastic. You will need some anti flex strength in the support to stop the new guard flexing & bumping into the chain. So I guess you will be using an invert L design. Remember to turn the inner lip down 5-10mm to strengthen it in length. Then on the two upright parts, bend 3-5mm of each edge to reinforce those, hope that makes sense.
Edited by Mohawk, 28 February 2013 - 06:23 AM.
I'm trying to picture that in my head... I guess I'm mostly confused about the upright parts you describe, and where the bends would be.
End of thread · 6 posts recovered Wayback Machine snapshot 31 Oct 2013
