Tried to understand the Bluesea website's "Circuit Protection" and failed....,
so maybe someone here knows:
As per below, I have added a fusebox, switched via a relais.
Must I also place a fuse between the battery + and the relay?
If yes, which amp rating?
On the box are/will be:
2 Powerlet sockets (1 for Garmin, 1 for smartphone)
Powerlet plug for heated gloves
double FIAMM horns
SDC Led voltmeter
a small PC fan (0.12A) on the R/R cooling fin
Had a productive day, adding a 2nd powerlet socket and fusebos.
Using some materials I had lying around made up a bracket.
[image: IMAG1882.jpg]
[image: IMAG1887.jpg]
[image: IMAG1885.jpg]
Gimme shelter...
[image: 2013-05-05_20-36-02_HDR.jpg]
