I have a problem with my 5th gen, about 6-7 min after i start running the bike i get a FI light.... checked the light, blinked 8 times. Ok, so its a TP problem. I can tell from when trying to go on it hard from 7k+ it just walls flat on its face. So I checked the TP sensor and its good, now i just have to find the sub-harness to test the wiring.... and there is my problem.... where is that 10p grey connector that goes from the injectors, TP, air control valve, and IAT?
Tp Sensor Wiring
3 posts Started 19 Jul 2013 Last recovered post 20 Jul 2013 Wayback Machine snapshot 10 Oct 2013
I think you mean the ones lurking behind the upper left hand side of the frame (into which the Power Commander III USB plugs). The pic below shows where mine are now, which may not be exactly where they are on an unmolested 5th-gen, but you should find them around that area. (I moved mine so that they were more accessible.)
[image: P1030401x.jpg]
thanks you for showing me, tested the subharness, the wiring harness and the TP there all good... must be something going on with my PC3
End of thread · 3 posts recovered Wayback Machine snapshot 10 Oct 2013
