'06 6th gen; 32,000kms; Australian. Non ABS.
I'm trying to troubleshoot an electrical gremlin. My battery is discharging. Takes about 2-3 days with normal about town use to go flat. I popped the voltmeter on it and at idle it's getting 11.2v; at 4000rpm it goes up to 12.2v. Not sure what i should be getting at idle; guessing 12.5 to 13?
I've had the bike about 4 months; it came with a trickle charger and plug fitted so I charge her up overnight every couple of days, which limits the inconvenience so far.
Main fuse bank (RHS below throttle grip) all fine. No noticeable burning smell. Already replaced the battery (the old one was fine though, d'oh); issue persists.
Done a bit of research already and the consensus seems to be either faulty regulator/rectifier or stator.
Before I start purchasing parts and swapping out I thought I might check with the knowledge bank here.
Is there anything else I should check first?
Should I replace the reg/rec first, then if the issue persists replace the stator second - or vice versa?
Is there anything I can do to determine if one or the other is causing the issue? If I take off the stator cover and have a look would a lack of melted wiring indicate the stator is ok?
Or could it be something else?
I have an electrical sparky mate who works on cars only who I can use for tools and brain picking; my mechanical expertise would only be 3/10 (but keen to learn heheh), so am going to have a go at fixing this myself.
Any advice or linky to similar issue thread on here before I start shelling out coin on parts would be greatly appreciated. Thanks!
