I have gone into my clutch on an 06 VFR with about 3,700 miles in order to research a buzzing sound that I hear at around 4000 rpm and found that the clutch lifter rod has some burring and wear lines on it. I have included some pictures. In the one with the full rod area A heading towards area B has 2 etched black lines that do not catch a fingernail, a smooth discolored area and 2 small gouges that barely catch a fingernail. These are seen better in area A closeup shots. Area B is a lightly burred area that entends between the 2 arrows in the middle of the rod and heading towards area C there a two gouges almost in the same place and size as the ones in area A. The rod when you run it across 2 glass tables roll unevenly and it is pretty clear that it is out of true. I am going to replace it of course but does anyone have any ideas as to what may have caused this?
- [image: full rod.jpg]
- [image: area A.jpg]
- [image: area A closeup.jpg]
- [image: bar end.jpg]
