Also my hydraulic pressure feels fine. With the malfunctioning slave cylinder did the lever feel give you any clues as to what was going on?
Not one iota - lever 'feel' was totally normal. But I started to get clutch slip, and it got progressively worse until the bike was basically un-rideable once hot. I ended up doing the clutch replacement at my parents place, because that's where I was heading the day it reached terminal point :mad:
Because the piston will stick halfway along its bore, the only physical change you could notice is the master reservoir being a tad low, as not all of the fluid is returning to it when the clutch is engaged. Not easy to notice with a steel master cylinder.
Ok, not sure i can "feel" any difference at the lever, and i did not quite have a chance to jump on it as cold as normal but i could not detect the issue after the clutch fluid flush. Not sure how a mushy lever would feel, but i would venture to say i did not introduce air in the process. Don't let just the brown fluid fool ya, i couldn't believe the shmegma down that reservoir. Another ride planned Friday, will see.
When you flushed the clutch fluid - did you do it from the master to where the line meets the slave? That will leave a lot of crud in the slave itself (that's where it gets into the system in the first place, it's a very hot and dirty environment for a hydraulic assembly to live).
There's two options to really flush it - one is to pull the slave off and pump the lever so the piston is pumped out of its bore and into a bucket.
The other way is how I did it - I was pretty sure I had a piston not fully retracting, but to pump it out would mean no proof of this - so what I did instead was to drain the master reservoir (and remove the little metal widget that sits over the outlet in the bottom of the reservoir), cover it with old towels, and then use a c-clamp to wind the piston back into the bore. Sure enough I got major resistance, then bam! it pushed through the sticking point and back to where it belonged.
The towels caught the explosive ejection of fluid up top...
Then I used old brake fluid (sitting on the shelf too long, hydroscopic) to refill the reservoir, and pumped the piston out of the bore.
You can put a new seal kit through it, they are cheap, but I just cleaned up the bore and piston and reassembled with fresh fluid, no leaks, no further problems.
