6Th Gen Hazard Issue
6 posts Started 16 Apr 2014 Last recovered post 19 Apr 2014 Wayback Machine snapshot 30 Apr 2014
When the hazard switch is engaged the turn signals shut off instead of flashing. And then go back to running lamps when the switch is not engaged. Wire harness fix was done last yr, any ideas? I've tried the wd40 trick to the switch didn't work.
Hazard  switch  ?
Somebody  added  on  ?
It   has   to  have  it's  on  flasher.  I  would  check  it  first  and  then  for  fuses  and  check  the  bulbs  make  sure  the  right  type  and  makes sure  the bulbs  are  not  blown .
Hazard  switch  ?
The newer 2004+ models have hazards -- we early 6th gen folks got shafted.
Darn  screwed  again  ..
They work great in the nasty heavy rain, Ive used them a few times
I'm actually buying a replacement switch set for my 03 to add the Hazard circuit into my bike with some LED strobes front and rear.
End of thread · 6 posts recovered Wayback Machine snapshot 30 Apr 2014
