Fuse Block Mounting Location?
7 posts Started 6 Jul 2014 Last recovered post 5 Sep 2014 Wayback Machine snapshot 29 Jul 2016
A while back, I bought the VFRness for my 6th gen and it's been great. I bought the bundled pack to get the fuse block. I figured I'd install it later.
It's been a year :unsure:
I'd like to fix that! I popped off the seat (I have a Sargent) but I have no idea where to mount this thing. Does anyone have any pictures on where they put theirs? I did a search but only found 5th gens.
I mounted mine under the seat on the right side , I will try to remember to take a pic of location tomorrow.
6th gen under the seat .
Under the backbone and in between the rear brake master cylinder and the battery, there is plenty of space , on mine anyway .
Dont know ABS thou , the pump mite by in that location .
Mounted my FZ1 Fuse Block under the seat next to the rear brake fluid reservoir. Just fit! (2008 ABS VFR)
[image: P4230047.JPG]
Edited September 5, 2014 by BonemanVFR
What he said. I just used a couple pieces of sticky backed velcro to affix it. You can tap into the tail light right there for switched power. If you have a Sargent seat the thicker pan may rub against the top, but it causes no harm.
[image: PCV and Tightwads Fuseblock and VFRness setup]
Follow Alan's note. :-) Perfect spot for tightwad's block. Basic simple and excellent. Hope this helps.
Dave.
End of thread · 7 posts recovered Wayback Machine snapshot 29 Jul 2016
