Standard Seat Vs Low Narrow Seat
3 posts Started 10 Dec 2014 Last recovered post 10 Dec 2014 Wayback Machine snapshot 24 Mar 2016
Hi.
I would like to ask you to help me with this question:
One month ago i purchased a used VFR 1200 DCT equipped with standard seat (...i believe).
Today I received the Low Narrow Seat that I ordered as an accessory (genuine Honda).
The surprise... comparing the two saddles, there is very little difference (!!!) They look almost identical...
Someone who has had them both and can confirm that it is so?
(maybe my used VFR had already Low Narrow Seat..)
Thank you all for the help.
Did you compare part numbers on the seats?
I have both.  Yes, they look very similar, but the low seat is shaped a bit differently.  The front part near the tank is a bit narrower and the sides are cut a bit differently.  It's subtle, but if you look carefully, you'll see the differences.  The cover material is almost as slippery as the stock seat cover, but it seems a tad softer, or maybe the foam underneath is softer too, I really cannot tell which.  The end results is my butt tends to slide a bit less on the low seat.  I ride on the low seat around town and switch to the stock seat for sport touring.
Check the P/N molded on the underside.  The low seat has a different P/N.
End of thread · 3 posts recovered Wayback Machine snapshot 24 Mar 2016
