The first thing the manual tells you to do is to "Remove the muffler". Hard to see what that's got to do with the shock, but I'll bite. Off with it. Then, Honda drops the bomb on you. "Remove the rear fender." Looking at that I thought "Hmmm . . . how hard can that be, it just holds the license plate, right?" How naive I was . . . When Honda says "Rear Fender", they mean the tray under the seat - not what's replaced by a "Fender Eliminator" kit. Honda has designed the ABS bike in such a way that the hose / adjuster cannot be threaded out without removing the fender under the seat.
[image: DSC06334_zpsb478a434.jpg]
The seat and rear cowl come off, then the tray. After removing the "fender" and license plate, remove the battery and pull the wiring in the pocket next to the battery up and out. Also detach the cable from the seat latch. There are two collar bolts (5mm hex) that are upside down at the rear of the tray. If you have anything mounted under the seat, in my case a Power Commander and electrical distribution box, those come off as well. Once all that's removed, this is what you'll end up with. Yeah - no fun. Still a long way to go. My chainguard is removed because I have a hugger and the tray could not come out with it in place. Otherwise the stock chain guard could be left alone. Note the tone ring on the inside of the rear rotor that generates the signal for the ABS unit.
[image: DSC06369_zpsf11776cf.jpg]
The object is to remove the adjusting knob from the bracket (yellow) and thread it out with the hose (green).
[image: DSC06335II_zpsf1f19eb2.jpg]
The hose (yellow), threads underneath the rear ABS unit, over the brake hoses (at the green arrow) and terminates at the shock (orange). Rather than remove the knob from the adjuster as the manual specs (with the "Oh Sh*t" spring and ball bearing that likely end up under a workbench), I removed the bolt holding the brake hoses (white) and moved the hoses aside to make room to thread the unit through intact.
[image: DSC06336II_zps7a67355f.jpg]
If you're thinking of buying an ABS shock for your non-ABS bike, you'll want to be sure the seller includes the mounting bracket and hardware. Otherwise you'll have to buy it separately or come up with your own mount. The bolts (green) are unequal length as the bosses are not the same (red). There are also two bolts that hold the adjuster unit to the bracket (yellow). If the bosses (presuming it has them) on your step are not threaded you'll need to drill and tap those too.
[image: DSC06338II_zpsa6cca307.jpg]
Now that the brake hoses have been moved aside (yellow), the adjuster hose (green) has been moved outside the bracket and the adjuster (also green) is ready to thread through the swingarm with the shock.
[image: DSC06342II_zpsa0590b5b.jpg]
I only threw in this photo (sorry about the crappy quality) to show the rear ABS unit (yellow) and brake hose attachment (green).
[image: DSC06344II_zps94da3f40.jpg]
Lift the rear of the tank and remove the 17mm nut that holds the shock to the frame.
[image: DSC06346_zps03ead8fe.jpg]
Lift the swingarm. I used a floor jack, but you could just as easily do it yourself by lifting it and sliding some wooden blocks, a crate or anything sturdy underneath. A helper could also do it, it's really not very heavy. If you have the fender removed, a ratchet strap around the subframe and a wheel stud would also do.
[image: DSC06373_zps484209a7.jpg]
Triangle removed. I might have been able to wrestle the shock out with the dogbone in place, but it's just a 17mm nut and an 8mm hex head bolt (opposite) to get it out - made things easier. A ratcheting end wrench is useful here (it's a nylock nut) - no room to get a socket in there.
[image: DSC06353_zps585cc5ff.jpg]
Hex head bolt on the opposite side (again, sorry for the lousy photo).
[image: DSC06354_zps1526accf.jpg]
Shock coming out, followed by the pre-load adjuster.
[image: DSC06355_zps8462455a.jpg]
Finally out, adjuster knob left in place.
[image: DSC06357_zps74086c86.jpg]
