Before the flames start coming here is the proper way to straighten your rotors. Understand that this is my opinion and my process and use of the instructions on your machine is your responsibility. I do not warrant the process and am sharing this for educational purposes only.
Background, 2000 VFR with 26K miles, just did the brakes and new Pilots. Hence the problem, either I or the shop was sloppy on handling the front wheel. This caused an annoying shake on braking, and when I was coasting to a stop with the front lever pulled to allow the pad to drag, received an obvious warp feeling in the bike as the bike would grab then coast at the speed of the front wheel turn. Nothing to drastic, but felt out of spec.
Tools needed:
Zero Dial Indicator
5mm allen wrench
Large pry bar
Sharpie
Pen
Paper
May need friend to hold bike wheel while prying
The rotors are made of two parts the braking surface and the inner mounting plate. There are two scenarios, either the brake surface is warped or the mounting plate is bent. Since the mounting plate is more suspect I assumed that when I began. Also note for the anti-straightites, brakes need their strength in the X-plane, this process is manipulating the rotor in the Z-Plane, and only by +/- 20/1000th of an inch, no where near the deflection to cause metal fatique. Also do not hammer, shows total lack of control, this is a delicate machine put the persuasion away and use your pry bar. Note I am 6'3" & 285lb with a will to bend, the rotor was relatively easy to move...and the pressure you place on the tire/rim is minimal, as long as you wrap the pry bar all should be fine. The key is to take it easy and watch the ZDI.
Step 1) Get yourself a VFR that has a brake rotor rub or warp shimmy.
[image: DSCN0094.JPG]
Step 2) Unload your Zero Dial Indicator (ZDI from now on, hate typing)
[image: DSCN0095.JPG]
Step 3) Remove the front fender with 5mm allen and a twisty action
[image: DSCN0096.JPG]
Step 4) Mount ZDI on the lower front fender bolt tap
[image: DSCN0097.JPG]
Step 5) Mark the rotor with the Sharpie at the point where the brake rotor connects to the mounting plate
[image: DSCN0099.JPG]
Step 6) Number the sections, 1-7 with the Sharpie (Tire rotating as going forward, 1 should be the highest reading, assuming that the rotor was hit to cause it to be pushed in to the wheel), I suggest on the outer most edge, as the pads will wear it off after 4-5 tire rotations
Step7) Set the ZDI on the first line you drew at section 1 and zero it out, Rotate the wheel forward and note the beginning reading and the reading at the end of the section. Continue with each section
[image: DSCN0100.JPG]
Step8) Take measurements at the outer rotor edge, inner edge, and then on the mounting plate. This will help to isolate the issue and what will need to be “adjustedâ€
[image: DSCN0102.JPG]
Spec for the run out on the rotors is 12/1000th, that is the total deflection from the highest to the lowest.
Here were my readings
Left Rotor
Outer
Begin / End
1) 0 / 0
2) 0 / -1
3) -1 / -12
4) -12 / -19
5) -19 / -10
6) -10 / -2
7) -2 / 0
Inner
Begin / End
1) 0 / 0
2) 0 / -1
3) -1 / -11
4) -11 / -17
5) -17 / -8
6) -8 / -5
7) -5 / 0
Plate
Begin / End
1) 0 / 0
2) 0 / -1
3) -1 / -10
4) -10 / -16
5) -16 / -7
6) -7 / -3
7) -3 / 0
Right Rotor
Outer
Begin / End
1) 0 / -1
2) -1 / -10
3) -10 / -20
4) -20 / -12
5) -12 / 0
6) 0 / 0
7) 0 / 0
Inner
Begin / End
1) 0 / -2
2) -2 / -10
3) -10 / -18
4) -18 / -12
5) -12 / 0
6) 0 / 0
7) 0 / 0
Plate
Begin / End
1) 0 / 0
2) 0 / -10
3) -10 / -18
4) -18 / -9
5) -9 / 0
6) 0 / 0
7) 0 / 0
This confirms 2 things, different ways. Since the ZDI is showing the rotor pushed in it confirms the rotor was either hit or moved from sloppy handling. It also confirms that the mounting plate is the weak link, and the rotor is in fact not warped. You may be asking why the numbers vary up or down on the same rotor as you move in. All perfectly plausible with imperfection in the wear and the original turn when the rotor was new.
Now the fix, I need to bend the mounting plate to zero, with the ZDI on the point that is furthest from zero I get the pry bar behind the rotor to leverage the wheel to push the plate out, away from the wheel. This is a very delicate process and you have had to work with metal before to understand how to bend it without stressing it, and to get it to move to zero. Don’t worry if you move it to far, you can bend it back. I wrapped the pry bar in a shop towel to minimize and scratching. Watch the ZDI to make sure you keep it in spec. I found that I moved it about 20-35 thousandths past zero to get the plate to settle at zero.
Moving the rotor out (pardon the blurry picture - note I left the towel off to show where you set the point)
[image: DSCN0103.JPG]
Same shot further back - the key is to get behind the strut that connects to the rotor, NOT THE CIRCLE that the rotor floats on.
[image: DSCN0106.JPG]
This is the way to push it back if you go to far you pry the strut against the lower part of the mounting plate
[image: DSCN0107.jpg]
Further back
[image: DSCN0108.JPG]
After adjustments - measurements
Left Rotor (Did this one second, tried for perfection after feeling out on the right...this was lucky)
Outer
Begin / End
1) 0 / 0
2) 0 / 0
3) 0 / 0
4) 0 / 0
5) 0 / 0
6) 0 / 0
7) 0 / 0
Right Rotor (Did this first did not try to get perfection)
Outer
Begin / End
1) 0 / -1
2) -1 / -2
3) -2 / -2
4) -2 / -2
5) -1 / 1
6) 1 / 1
7) 1 / 0
Took the bike out and made about 8 hard stops and a slow stop, no shake and no shimmy and no brake drag as the wheel rotated. Felt like a new rotor, 1000% better then before. I then brought in jacked it up and checked the run out while the rotors were hot.
Left total deflection 2/1000th Right total deflection 3/1000th
All well within spec of 12/1000th
I will work with bike over the next few months and monitor the run out. I will assume that I have at least one more adjustment as the heat gets into the brakes, but then it should be set. I will post follow-ups as I track it myself. Good luck if you take this on, this was my experience, yours may vary.
Edited February 28, 2011 by ferchja
