Shock Refill Required?
4 posts Started 7 Feb 2015 Last recovered post 8 Feb 2015 Wayback Machine snapshot 13 Mar 2015
Quick question -
I have an '02 Non-ABS... looking to buy a used OEM ABS rear shock with remote preload adjust.
I have found a fellow who will sell me one for a reasonable price - it has only been ridden for 10,000km (~6k miles), but has been off the bike for just over a year (he upgraded to a Penske).
He has advised that I should have the shock refilled since it has not been under pressure/load for a year.  Is this necessary?  I wouldn't think so, as I'm imagining buying an OEM unit from Honda that may have sat on a shelf for 5 years... but maybe its different if it has been ridden on versus not?
Feedback appreciated!!
Mike
Quick question -
Mike
Be sure to get the remote preload unit mounting hardware from him, you'll need to buy it OEM or otherwise come up with your own mounting system. I have a post showing how to remove the shock from an ABS model with pics.
The shock unit not being used for over a year does not have anything to do with it possibly needing a nitrogen gas re- charge. If that is true, then every nitrogen gas charged shock out on motorcycle parts dealer's shelves over 12 months would also need a recharge. It could be that the shock might have developed a leak..... and it's the sellers's way of you possibly buying it "in as-is condition".....
As long as you're replacing the shock, it would be the perfect time prior to installing it to send it to Jamie D. for a re-work - new spring and valving.  Send the forks while you're at it and you'd have the suspension completely sorted for your weight and riding style.
End of thread · 4 posts recovered Wayback Machine snapshot 13 Mar 2015
