Hey guys. I'm not currently running a dash on my vfr800 streetfighter and was wondering if I would have any drawbacks from cutting off the stock dash connectors and capping them until I reuse them for an aftermarket one.
I'm not super electrical savvy so I didn't know if they still made an active circuit even unplugged to the ECM or anything.
I've had a quick look at the wiring diagram and I don't see any circuits that run through the dash and back to the bike. Why don't you first unplug the dash and see if the bike runs? It would probably be better if you could avoid lopping off the connectors. You may be able to get extra connectors to plug right in when you fit the new dash. Try www.easternbeaver.com
Hey man. Thanks for the suggestion. I've actually been running the bike without them plugged in for a few months no but they simply take up too much space under the tank. I just wanted to clear that they will be good to be capped. I am having a hard time finding the space for all of the harness seeing as I haven't completely trimmed it yet. Currently the relays and original dash connectors are stashed in front of and to the siside of the air box.
I'd like to know what is absolutely critical to keep and what can go.
End of thread · 3 posts recoveredWayback Machine snapshot 22 Feb 2015
