I'm new here, first post... thoroughly enjoyed reading all the informative posts...just pre-viewed my post and looks like pic of Connectors doesn't show my labels.
I picked up a 02 VFR800 ABS back in December with 8k, picture (below as I received it), looked good (I thought for age), sounded good and price was fair, from a big dealer up North in Yorkshire, I'm just North of London in county Suffolk.
However dealer had silver 'painted' the rusty exhaust even the banjo bolts on the front callipers!! I have since noticed he does this on all his used bikes if you look.
I've done a lot of work since then...Motad Headers, Samco Coolant hoses (with gaskets and Samco clamps), new Wax Idle Unit as it was completed clogged (see picture) and had the high 4K RPM issue, ABM Multiclip handlebars (cheaper than Heli's and more adjustment, gorgeous billet Ali), Gear indicator Cable Tied to Clutch Reservoir, Injectors cleaned & tested, Forks re-built by MCT in Stowmarket, UK (highly recommend), new Oil Cooler Lines, Intake Boots, K&N filter, ASV Levers...and a VFRness and R/R and here is the problem (pictures below...)
Still to do...Powder coat wheels and some Road Pilot 4's
Connector with problem is the 4 spade Top Big White Conn...where does it go?? supposed to go with small Conn with Red wires I think but...??
Any help would be much appreciated...going to email Tightwad direct, but thought I would ask on here as well, time's a wasting and Spring is looming :-(
Installing the VFRness is as easy as it could be. You will need the following tools:
Allen wrench for body panels Small 8mm socket on extension(or a nutdriver) for the tank and the R/R bolt(just one) 10 mm socket or wrench for the battery Small piece of wood or similar to prop the tank up (or a loving someone to hold it)
The following items must be removed:
8 Allen head bolts and 3 panel clips to remove the body panel (there are 3 different bolts, keep them separate) 2 more clips on the battery cover 2 bolts on the battery(always start and end with the ground wire) 2 bolts at the front of the tank
Prepping the bike:
1. Remove the seat and set aside 2. Remove the battery cover by pulling on the 2 black plastic nubs and set aside 3. Remove the ground cable bolt(right side) from the battery using the 10mm socket. Watch to be sure the nut in the battery terminal doesn’t fall somewhere. Flex the negative cable aside, so it is out of the way. 4. Remove the positive cable bolt(watch the nut again) 5. Remove the rubber strap from the top of the battery and set aside 6. Remove the battery from the tray and set aside 7. Replace the 30 amp fuse in the main holder with the 15 amp version in the little bag supplied with your VFRness. 8. Remove the two 8mm bolts from the top of the tank, near the handlebars. Set these somewhere safe. 9. Remove the two trim clips under the fairing, and the 1 trim clip in the black panel behind the front wheel near the top of the panel. These are best removed by using a small screwdriver or key to push in the center about ¼”, then pull the trim clips out. Set these aside with the tank bolts. 10. Remove the 2 Allen head bolts from the top of the right fairing panel, remove the 4 from the side of the panel, and the 2 from the front (in the black part behind the front wheel). Note which length and style of bolt came from which hole. Two of them have a shoulder on them. Two others are slightly shorter(from the black part behind the wheel). The other 4 are the same, and connect the fairing to the top/from fairing. 11. Carefully pull the panel back and out from the bike. There is tab on the front fairing that catches the panel…slight pressure will disengage it. 12. Locate the R/R. It has fins, and is bolted above the radiator on the right side (under the panel we just removed). Remove the 8mm bolt at the back of the R/R…we will be putting a wire under here. 13. Follow the wires from the R/R to the plastic connector. This is usually located inside a clear rubber boot. 14. Push the rubber boot away from the connector, and disconnect the connector by push down on the locking tab while pulling them apart. 15. Lift the tank(it hinges at the back, neat huh?), and prop it with a small board, pole, etc.
Installing the VFRness:
1. Lay out the VFRness. Note the end with the connectors that look like the R/R connector. Check to be sure they match the connections on the bike. There is a male and a female connector, they only fit one way. 2. Starting with the fuse end of the VFRness, feed it along the top of the radiator hose to the inside of the frame of the bike. Reach down from the top, and pull the harness up along the frame until it is level with the top of the frame. 3. Following the thick fuel lines, route the harness towards the left side, and a little bit towards the back of the bike. 4. From the left side of the bike, continue pulling the harness until most of the length is out the left side. 5. The fuse end must end up with the other fuses, so routing it under the black subframe behind the battery is the best way. 6. Carefully thread the fuse end along bottom of the subframe until the fuse can come out the subframe near the other fuses. 7. Be sure the VFRness is rotated such that the positive connection, 10 inches from the fuse, comes out near the positive cable. It should reach out about 4.5 inches, enough to bolt to the battery but not have excess in the way. 8. Reinstall the battery in its tray, and test that the positive cables both reach the battery terminal. Go ahead and bolt it down now, main cable on the bottom, VFRness cable on top. 9. Reinstall the rubber strap, but do NOT install the negative cable at this time. 10. Once all lengths have been confirmed, and it fits, use the supplied zip ties to hold the VFRness to the fuel lines….this keeps it from moving around and chafing. 11. Lower the tank, and reinstall the bolts. 12. On the right side of the bike, connect the R/R connectors to the VFRness connectors. 13. Reinstall the R/R bolt, with the ground loop under it and tighten. 14. Carefully tuck the Relay and wires against the frame. There isn’t a particular place they need to be, just close enough that they won’t interfere with the body panel. 15. Reinstall the negative cable(but not the battery cover yet)
Off topic, where did you get the VFR V4 VTEC white and red decal?
I believe that's standard OEM markings in European markets. Note also the markings on the front fender and the metal serial # plate riveted to the frame in the second photo. I have a set of Euro spec 6th gen hard bags and the logo on them says 'VFR' rather than 'Interceptor' as in the US.
