My brother sent me this link, Seems like pretty solid info.
Something to read this Winter!!!
540 RAT – TECH FACTS, NOT MYTHS MOTOR OIL ENGINEERING TEST DATA
https://540ratblog.wordpress.com/
Top Rated oils w/o additives added: ( This first one is Not recommended on any vehicle with a Cat )
4. 5W30 Motul 300V Ester Core 4T Racing Oil, synthetic = 112,464 psi
This Motorcycle Road Racing oil is from France and comes in liter bottles (slightly more than a quart). At the time this oil was tested in spring 2014, it cost $24.25 per bottle. And with the shipping cost added to that, the final cost was about $33.00 per bottle (shipping was all inside the U.S.), making it THE most expensive motor oil I’ve ever tested. But, since this oil is in the INCREDIBLE wear protection category and is ranked number 1, for oils just as they come, right out of the bottle, with no aftermarket additives, you could say you at least get the best possible wear protection available, for that super high price. This is an extremely impressive motor oil just as it comes, right out of the bottle. So, no aftermarket additives should be used with this oil, because that would only reduce its capability overall.
zinc = 1724 ppm
phosphorus = 1547 ppm
moly = 481 ppm
calcium = 3141 ppm
TBN = 7.4
This oil contains sufficient amounts of the components required (detergent, acid neutralizer, etc) for normal change intervals in street driven vehicles. But, it has way too much zinc/phos for use in cat equipped vehicles. However, it is well suited for Race Cars, Street Hotrods and Classic cars.
7. 5W30 Oil Extreme Motor Oil, API SM synthetic (per the Oil Company, even though synthetic wording is not shown on the label) = 110,286 psi
The Company claims this oil contains their proprietary formula of calcium petroleum sulfontate EP (Extreme Pressure) technology that is NOT found in any other motor oil. They also claim that it will provide 5 to 7 more HP, 7 to 10% better fuel mileage, cut engine wear in half, and will extend drain intervals two or three times safely. This oil is endorsed and promoted by Tech Author David Vizard. And he was so impressed by this oil’s performance that he also became a share holder in the Company. The results from the “Dynamic Wear Testing Under Load” performed here, fully supports their claim regarding wear protection. So, their hype about that, turned out to be absolutely true. And since this oil beat nearly every high zinc oil I’ve ever tested, it also proved another one of their claims, that using zinc as the primary anti-wear component, is outdated technology.
zinc = 765 ppm
phosphorus = 624 ppm
moly = 52 ppm
calcium = 7,652 ppm
TBN = 23.2
10. 5W30 Mobil 1, API SN synthetic = 105,875 psi
zinc = 801 ppm
phosphorus = 842 ppm
moly = 112 ppm
calcium = 799 ppm
TBN = 7.5
Looks like I'm staying with Mobil 1 5w30.
