Curious to find out if anyone has a detailed list of the key differences between the two engines? could a 2006 engine be swapped straight into a 2002 bike? as far as I can see the only differencea are the vtec actuation and a revised front wiring harness. The workshop and service manual as well as part lists appear to indicate the two are interchangeable.
I'd appreciate if someone had a definitive answer?
Regards
Chris
