Hi all
Finally got around to fitting the HID-Xenon H7 bulb to the low beam of my 1200 this morning.
I've posted previously about fitting these on my 6th Gen and they've proved so good at getting the attention of cage drivers that I decided to buy one (£50 - yikes!) for my 7th Gen. Obtained from HID City.
Firstly, the screen, upper centre cowl, middle cowl (side fairings to me) and upper side cowls all need removing to gain access to the headlamp assembly, which unscrews via 4 nuts and disconnecting the single electrical connector for the 2 H7 OEM bulbs. There are videos on Youtube on how to do this along with the Service Manual available on download here so I wont go into removing them.
Firstly, I needed to know where the ballast & igniter would fit without fouling the forks. The ballast fitted nicely but I had to cut away a few pieces of plastic as shown in the next 2 pics.
[image: IMAG03651_zpsa4joajdh.jpg]
[image: IMAG03661_zpss5pxxut1.jpg]
The wiring for the HID-Xenon requires some modification, cutting & soldering of both the wires to the bulb and the replacement kit too, so I was a little concerned but it's worked out ok. To start, I put the new bulb in place and you can see the wires from it have different connectors on the end. That's because they go via the supplied igniter & ballast (not sure if it is ballast but it's necessary). So I now needed to move the weather cover from the original wiring to cover the wires from the new bulb.
[image: IMAG03671_zpsghscaaaq.jpg]
So cut the wires, swap the cover over and solder them back in place. Managed to use the oem insulation on the original wires, used heat shrink on the new ones.
[image: IMAG03681_zpsqul9slnj.jpg]
Next I connected the HID-Xenon all up...
[image: IMAG03691_zps8vuragnl.jpg]
Then I re-fitted the headlamp unit and connected it up to see if it worked.
[image: IMAG03701_zpsldoxnvzx.jpg]
And compared to the oem high beam bulb...
[image: IMAG03711_zps0fhshodr.jpg]
I don't have time this morning to put the bike back together as I'm off to work shortly but hopefully I'll have time this weekend to re-fit the fairings and take a look at the beam distribution. I'm not worried as the 6th Gen has proved that these bulbs work in standard reflectors but I am aware that this mod is not easily reversible - well, unsoldering & re-soldering the oem bulb but it's not exactly a 10 minute job.
I still have to hold all those wires in place once it's all back together and weather cover the 2 spade connectors into the oem wiring connector. The ignite will attach (sticky Velcro) to the inner side cowl.
Still, the results on my 6th Gen are definitely worth it so I'll keep you advised.
