Captain 80sOEM or aftermarket friction disks? I know when I've installed Barnett clutches on my bikes it definitely moved the friction zone in, but got better the more miles I got on it. And if it has been sitting for a while the first shift into 1st can be abrupt.
I went aftermarket, but I swapped them out because the existing set was doing the same thing, and I was hoping to fix it simply :-(
thx113
That's the one, yes I suppose you are right. Weak spring will probably allow slip.
When I got my VFR there was 10mm of travel from the handlebar to fully disengaged clutch - I thought I needed new plates.
After bleeding the clutch for a while to remove the brown sludge, the clutch now works perfectly.
That bush is another possible contributor - they can be found in tourmax kits (bush, rod, hat shaped diapragm) for less than just the bush alone from Honda. If you need one of these kits in a hurry I can send you one if you replace it.
Thanks Jeff. Might try replacing the bush (nothing else left :-( ), but there's no hurry really. I'll ride the 1000R until then.
tomk1960
I experienced the same problem with the low mileage '83 VF750F that I sold last fall. http://www.vfrdiscussion.com/forum/index.php/topic/79244-shifting-hard-when-cold-possible-cause/
I went through the entire brake and clutch system and rebuilt everything, installed new pads, and new EBC clutch disks, flushed and replaced fluids, etc. The bike would do exactly what you described when it was cold and once it was warmed up, the problem went away and the bike shifted beautifully. I never figured out quite what the issue was unfortunately and told the buyer about it. He had another 750 that did the same thing and had no concerns. One thing I noticed is that the clutch slave cylinder is smaller than the one used on the '84 VF1000F. They look identical, but aren't. I was actually going to swap out the slave and sprocket cover (also different to accommodate the different slave) but ended up selling the bike.
I went through pretty much everything trying to pinpoint the problem. I found that the actuator rod was not pushing far enough to engage the clutch until the bike warmed up, so I suspect that the slave was weak and marginal in this application. That might explain why the VF1000F went to a bigger slave. Not sure if they changed the '84 750 over to the same one or not...
Yeah, I was really hoping you were able to pinpoint the cause Tom, but you up and sold the bike on me ;-) My instinct is for whatever reason there's not enough throw for the actuator rod. Just need to work backwards from there I guess.
thanks guys.
