Seems to be a few VF1000 projects so I'll jump in as well.
I just picked up an 84 VF1000F from another VFRD member. You may have seen it (orange) in the classified section. While it is not nearly the deal or in the condition of Jeff's (http://www.vfrdiscussion.com/forum/index.php/topic/82676-jeffs-1985-vf1000ff-project/) I still think it is worth the effort of bringing back to its former glory.
The VFRD member I got it from was not the previous owner so not much info came with it. Milage is unknown since there are no gauges. Engine rotates. All 5 gears can be engaged. Plastics look to all be there. Front brake works, rear one sticks. No keys, no battery. Clean title. VA inspection sticker from 2013 so has been sitting since then.
I won't really be able to start in earnest until finishing grad school in March but when I got home last night I did get a chance to look more closely. Plastics, tank, seat, and fuel tank came off.
The plastics are all there and not in bad shape either. Right side fairing had some repair work done in the past. Only noticeable from the back side. Some of the tabs are missing but nothing that cannot be fixed. With no key I did manage to get the fuel cap open. Tank was almost empty with only a few ounces of rotten fuel in it. I got that out and took a look inside. No surprise, significant rust so I'll give POR-15 a try unless someone can suggest something better.
Coolant was only down a few ounces so am assuming no static leaks (we'll see what happens under pressure).
No critters living in the air box. Filter retention spring clip is gone so previous owner used a piece of PVC to hold the filter in place.
Gauges are gone but there is some type of after market gauge spliced in. No idea if it works as there is no power on the bike right now.
Carb slides and butterflies move freely but the choke appears stuck. I'm assuming the bowls weren't properly drained and the carbs are full of varnish.
That said, my general game plan is to try to get it running if only to ensure no major issues or show stoppers. From there, I'll attempt to do a full restoration. I'd like to put it back to as close to original condition as possible.
Near term priorities:
-Carbs
-Fuel Tank
-Pull Cam covers so I can look at the cams.
Pics
Off the trailer and in the garage.
[image: IMG 0402]
[image: IMG 0403]
[image: IMG 0404]
Plastics, tank, seat, and air box removed.[image: IMG 0409]
[image: IMG 0406]
[image: IMG 0408]
'Gauges"[image: IMG 0407]
After market gauge spliced in.[image: IMG 0405]
Edited January 3, 2016 by Hawkeye Driver
