... Just a query on the change from the '07 to '08 'Blades: My data says the disc offset increased from 12.5mm to 15.25mm, but I don't know where I got those dimensions...
I think I now have almost all of the data for brake calipers for most sportish Hondas of the last 25 years. The F4-on CBR600s had 34/32 pistons and 5/8" masters; the early 600RRs had 32/30 pistons and 11/16" masters (this is what I have purchased for the above "soon-to-be" VFR). As you say, there is no way to tell from the outside which size pistons are used in similar-looking calipers, so I will measure them before I install them. I think F4i calipers are black, and I know I have a set of silver ones somewhere, but all the rest are gold.
I would consider the more advanced BPF forks, but the shorter length would be a problem. Besides, I already have a complete SP1 front end I could use for this bike...
My memory indicates that the disc offset (width) reduced and thinking about it again, from first principles it would need to be less to suit the '08-> narrower forks. I can check to confirm as I have both types here, but I'm very sure the offset was reduced.
Apparently the narrower fork spacing helps reduce the frontal area and hence wind resistance of the bike and also some steering inertia. But the frame needs to be designed to suit really as otherwise the narrower forks with fat USB legs can hit the frame. Not only that but the bottom yoke design can also impact on what fits what. Try to fit a flat CBR lower yoke on an RVT and it'll hit stuff. That gull wing bottom yoke is like that to clear things like the oil cooler, rad etc. Fortunately for us, these variations mean there's probably something out there that will fit almost anything we want.
I didn't realise the 600 ever used the 32/34 calipers, but I never had anything to do with the 600s. The 11/16" master cylinder is one of the crossover type. The lever design is such that they are virtually the same ratio as the later radials, so for all those the leverage calculation would be the same. But they are all very different from the earlier master cylinders, such as on the early 'Blades, VFR800, Firestorm, RC45 and many others. You simply cannot compare the piston size. The old style 14mm master cylinder is roughly equivalent to a 19mm in the new style (and also radials) with the longer levers.
For the RRW/X 'Blades with the 32/34 calipers, Honda used a 5/8" master cylinder (old style of course). These brakes were an improvement on the earlier 27/30 calipers with 14mm master cylinder. But as we know, the 14mm master cylinder works great with those 32/34 calipers. However, I do like very strong brakes and accept that it is possible to squeeze too hard in an emergency, something Honda have always been very keen to avoid. They try very hard to make good brakes.
Most of you won't remember the first disc brakes that simply did not work in the wet and I mean really did NOT work. Most bikes combined front discs with drum rears so you at least had some braking in the wet. The situation came to the attention of the government (Department of Transport) who thought new legislation was necessary to eliminate the problem. Fortunately they did discuss their 'Wet Weather Braking' proposals with the industry first. Honda was adamant that legislation was NOT necessary and that the notion of the problem being due to the stainless discs used was misguided and far from the truth. The oft recommended cast iron discs were not in fact the solution which in fact would be found in new better pad materials, about which they were researching and working very hard to come up with the real solution. Honda requested strongly that the DOT just hold off from introducing any legislation until the problem was really solved with new pads.
The rest as they say is history. New pad materials were developed and legislation was avoided and now years later, we don't even think to mention wet weather performance of disc brakes, it's simply not a consideration. Now that's progress.
What does puzzle me though is that Honda's main brake supplier is Nissin, hardly a surprise as they are wholly owned by Honda, but the brakes they use on the top of the range bikes are from Tokico who I believe are not similarly owned by Honda. Nissin do make radial calipers, but Honda don't use them. Odd.
