Best Tires?
3 posts Started 28 Feb 2016 Last recovered post 28 Feb 2016 Wayback Machine snapshot 15 May 2026
I have thought to change the rear tire of my vfr honda, but the previous owner apparently had a smaller tire, please, I might advise that number of tire brand will look better and I use it for long trips
If it is for your 750 then it is a 170/60/17. I have only put 1500 miles on them but am very happy with the Metzler Roadtec Z8
MrQuetzal
coupedupsubie
Provide us with the year of the VFR that you have. As the second poster stated some 750s have a 170 rear tire.
Tell us also a little about the roads where you ride and the "long trips" ad rate the following from most important to least important in how you ride and value tires:
Long tire life
Cold weather grip
Wet weather performance
Ultimate performance grip
Cost
If you reorder these to suit your most important criteria for judging then we can point you in a direction for a good quality tire that compromises to suit your needs best.
By the way, welcome aboard!
End of thread · 3 posts recovered Wayback Machine snapshot 15 May 2026
