First post and I'm afraid I'm asking for something. A little help.
I'm the proud owner of a 1984 VF750F with about 45,000 to 48,000 kilometers on it (about because the odometer stopped working at 41,300 kms last summer and I've been riding).
I was thinking it was good timing to do a valve adjustment on the bike. I've read a lot of posts here and other forms. I looks doable if you take you time and have some semblance of mechanical skills. I'm somewhat skillful and I don't mind picking up the tools that I needed over and above what I have.
Sooooo ... I start by taking a look at things, noticed a coolant leak from one of the water pipes ... nice, now I know why I had to top up the coolant rather frequently. I order up all the bits I think I should need for the endeavour. They get here and I start doing my thing. I've taken my time with this as I have no need to rush it. At first I was thinking I could just reach under and pull out the water pipe after loosening the hose clamps. After ogling things for a bit I figured there wasn't enough room to do so. The carbs are going to have to come out.
I wrestled them out ... I gotta tell you guys, holy f^c% are you kidding me???? Here is where the questions start.
First with the carbs, should the "assembly" of all four carbs have some stability to it? Once I got them loose they are sorta hang'n together like there's some taught elastic allowing them to float around some. It certainly wasn't what I expected. Is that normal for them?
Second, the valves were noisy. Not overly so, just with what I figure being 48,000 kilometers on the bike I should check them. I have two "service manual sources" one that says .005 the other says .006. I know that's pretty close but, almost all of the valves were way tighter than this. Less than .003 and only one that was .004. I thought I was measuring them wrong so I dug out the service manual and followed it through and double checked it all. They're all tight,
I was expecting things to be "loose", meaning to me that I would easily slide .005 feeler gauge under them.
Am I wrong in my thinking? I don't have anyone around to compare engine noise with. I haven't found any older VF guys in my neighbourhood just yet. All my riding buddies are more into newer bikes and when things get beyond an oil change they're challenged.
Some thoughts. Some help. A few jokes. Anything to set me in the right direction would be appreciated.
Cheers, Guy
aka, canuk_guy
