Simple Question: Starter Relay (Answered)
4 posts Started 15 Mar 2016 Last recovered post 15 Mar 2016 Wayback Machine snapshot 22 Apr 2026
Aside from the melty spot, that fourth slot is supposed to have something in it, correct?
As a background I took the bike ('04) off the trickle charger and the 30A main was blown. Just starting to dig in.
Edited March 15, 2016 by BrianF
Hi Brian,
According to the wiring diagrams in the 2002+ service manual and in the 2005+ standard wiring diagram (coloured) there are only three small gauge wires into the starter relay module.
* Yellow/red - starter switch
* Green/red - clutch & side stand
* Red - ignition switch
My guess is that your overheated connector is the red power lead.
ps. keep the great photos coming
Lorne
Hi Brian,
Got it, thank you.
And yes will do, many more to post.
I have seen melting of this connector on more than one bike. Most common cause corrosion or conncetors loosen their clamping force. Transition resistance causing heat and melting the plastic connector. Remedy: remove corrosion and use a pincer to tighten the female connector.
End of thread · 4 posts recovered Wayback Machine snapshot 22 Apr 2026
