hi all, my experience with rope plug -> patch
Tagging any disclaimers about this being just a sharing of my experience, I’m not suggesting any sort of suggestion and i personally accept the risk of being a cheap ass.
I’ve done this before on a few tires that still had good tread.
I got a staple in my rear tire a couple hundred miles ago and plugged it with a sticky rope plug, aired it up to 42 psi (per my consistent gauge) and had watched it since then. I put the rope in about like the instructions say; remove object, ream, shove in rope half way, give the split needle a twist (I see differing opinions about this, I do a full turn rather than half) and yank. Cut the outer ends off flat with the tire surface.
the only pressure variation was do to temperature – it lost no air in that distance. Next was to take the thing off and put an actual patch in it. So I removed the tire and pulled the rope plug out from the inside. the rope is actually sticking out vertically from the tire inwards, but the camera gets snow blind and it looks flat. I was very surprised at the force it took to pull the rope through the tread inwards. It totally dished the tire, the picture shows the area of the tire that pulled in, but not the depth there actually was. Anyway, there is no way for the plug to vacate outwards and to punch it in from the outside would be pretty unlucky.
For the patch, I get the 1/8” diameter quilled patches from napa. Rough the rubber with the tool, apply glue, let dry, pull the layer off the seal surface, and push the quill through the tire from the inside. pull the quill until there is a dimple in the center of the patch, cut quill to tread level. Roll over the patch like the instructions with the roughing/roller tool from an auto parts store says, then remove the outer plastic layer of the patch. For anyone else in a garage with no power, I don’t have power either, it just takes a long time with the scraper to get the “satin” look in the rubber.
I do see how the steel belting is physically damaged, strands are broken maybe by the initial puncture but I think mostly by the rasp. I only work the rasp maybe 3 times, not a bunch like videos I’ve seen and the instructions I’ve read, I think that damages too much of the belting vs cleaning the injury. I can see an argument also for replacing the tire because of this damage, but I think your mileage varies a lot on this. If I was able to shred a tires in a few thousand miles, I would plug to limp home, then replace the tire.
Anyway, I’ve done several patches over the years like this and they’ve been fine. I rub a bare hand over the patched area of the tire every so often to see if there is any sign that it’s starting to bubble or come apart, nothing. I commute though…I get to Palomar observatory only every few months and don’t really push on the street much except occasional dashes to 65, +-4n mph when space permits. for me,
patching tires like this is fine as a permanent fix, and I replace tires at the wear bars.
[image: plug -> patch]
