Hi all I'm not very mechanically minded so all the help I could get would be greatly appreciated.
I own a nc30 an awesome machine to ride but has started giving me an issue of spluttering and backfiring I can start up the bike no problem rev it in neutral with no problems but as I pull off through all of the gears the bike will splutter and backfire it oly started doing this a day ago.
Any help would be greatly appreciated
Did you recently fill up with fuel prior to the issue starting? If so perhaps you got a bad batch.
Also try pulling one of the spark plugs to check its color to get an idea whether or not your bike is running too rich. I'd also check the air filter to make sure it is clean so that you are getting enough air flow.
Rollin
Doe it still have power? Maybe the fuel pump died. I had that happen once and I could rev it in neutral but had no power to get it up to speed.
