Aight folks, need a lil help here.
I have a custom bike project that has been in process, on and off for a few years. Well, the frame is done, engine is mounted, and I'm finally ready to fir ethis sucker up and do some final testing before finishing it up, problem is .....I can't get ole girl to start :unsure:
Through the course of this project, I have gathered the following in hopes that the wiring and startup would be using as close to the stock VFR800 as possible:
98/99 engine
stock harness
ECU
fuel pump
bank angle sensor
relays
only things that are not from a VFR, is the ignition switch, and the engine stop/start switch......but I have wired those to match the 98-01 wiring diagram and continuity
I have everything plugged up and ready to test, ignition on, engine kill to ON, start button will spin engine...........but I have no fuel pump prime when engine kill is switched to ON, and obviously no start
so far I have checked all of the following per the service manual:
fuel pump (functions when directly connected to 12v)
engine stop relay
fuel cut relay
bank angle sensor
neutral switch
all fuses
kick stand switch (jumpered closed)
all of that tests fine.....but the fuel cut relay is not "relay-ing"...and the pump is not getting power
I have done most of what I can think of but if anybody has some suggestions, it would be much appreciated.
