I am retrofitting a 83 vf750f that was stripped to be a track bike back to DOT compliant. Got a center stand spring and plate and pivot pin off magna or some similar bike. Where does the spring plate pivot? Found a nub near the pinch bolt of pivot pin but spring too long for that location.
83 - 85 center stand spring
4 posts Started 13 Jun 2016 Last recovered post 14 Jun 2016 Wayback Machine snapshot 6 Jul 2017
That's where mine goes. Maybe the spring is wrong?
[image: File 13-06-2016, 4 23 02 PM.jpeg]
12 hours ago, mordantlyI am retrofitting a 83 vf750f that was stripped to be a track bike back to DOT compliant. Got a center stand spring and plate and pivot pin off magna or some similar bike. Where does the spring plate pivot? Found a nub near the pinch bolt of pivot pin but spring too long for that location.
If you give me the measurements of your spring, I will compare it to mine. I actually left my center stand off after mine was restored.
Thanks guys! That is the lug I had found. The magna must be different.. This spring is 4 7/8 inside the hooks..
End of thread · 4 posts recovered Wayback Machine snapshot 6 Jul 2017
