I understand that "covering the brake" is considered a best practice. I also understand the reasoning behind it, namely:
- it (theoretically) reduces reaction time in emergencies
- it (hopefully) makes it less likely the rider will panic and inadvertently grab too much brake too quickly
The reason for the parentheticals is that personally I'm not 100% convinced that the technique works in practice the way that it does in the classroom -- especially for non-elite riders. Still, as my wife regularly reminds me: I'm probably wrong. Here is my beef with covering the brake (two fingers):
- I really don't like the feeling of how it weakens my grip on the bars. My ring finger and pinky alone are much weaker than all four fingers. Also, it feels unnatural and is straining on the small muscles of the back of the hand. I can only maintain the configuration for a few minutes at time before my right hand desperately wants to relax back to a normal, full grip.
- It weakens my braking strength. Braking is, of course, still possible with just two fingers, but if I were trying to set a personal best for short-distance braking, I would without question use all four fingers.
- If I do proceed with two-fingered braking from a covering position, my outside fingers become trapped under the brake lever. Again, this feels super awkward and, in some cases, limits the lever travel and hence stopping power. I guess one could apply the brakes with the two inside fingers while simultaneously extracting the two outside fingers from beneath the lever, but I don't have that kind of nimble dexterity.
So, what am I doing wrong?
Or, better still: Are there any of you who had a similar experience when you first began covering the brake who eventually overcame these points of resistance?
