Engine replacement
2 posts Started 19 Oct 2016 Last recovered post 23 Jul 2017 Wayback Machine snapshot 12 Jul 2025
Hello, I've had to replace my engine on my vfr1200 2010 manual model because of some unknown oiling issue that effected the crankshaft, pistons etc..as the garage removed the engine and I'm fitting the replacement I'm not sure on the routing of the overflow/ breather pipe from the coolant expansion tank. Can anyone help with some photos or other pictures please.
Just curious as to the mileage on your vfr1200 as I have been considering buying one and i'm curious if it is a common problem or defect?
End of thread · 2 posts recovered Wayback Machine snapshot 12 Jul 2025
