BT023 or T30 evo ?
6 posts Started 8 Nov 2016 Last recovered post 12 Nov 2016 Wayback Machine snapshot 17 Jul 2017
The T30 evo's are $255 and the BT023's are $165 after rebate. Are the newer T30 evo's $90 better? Mostly freeway commuting style miles.
I only just swapped to a t30 evo rear. Definitely better grip, as for miles, only time will tell. I commute as well as a bit of scratching and would have about 20% left on the corners compared to the center on my last two 023 rears.
Just waiting for the front to wear a bit more as that is where I feel I needed more grip. The 023 front is a touch too hard I think.
For your uses grab a set of the 023 unless you're going to bring it on a lot of canyon runs with us :D
I went from 023 to T30 EVO but I'm an all weather commuter so my usage is different. The T30 are definitely better in the wet and more confidence inspiring. That said the 023 weren't bad by any stretch.
I'd say if you're mostly doing dry weather then go with the 023 but I'd be tempted to check the manufacture date and see how long they've been sat on a shelf.
BT023's came today. The Q3 rear it came with is past the wear bar can't believe I've done close to 4500 miles on this thing already.
17 minutes ago, thepretender
Got me beat by 2k miles in that time-frame, and you also ride your BMW. Nice one.
End of thread · 6 posts recovered Wayback Machine snapshot 17 Jul 2017
