Welcome!
This will be a thread where I show off the finished product(s) of my VF500 Resto-mod. I will only be featuring work I have done or modified myself. I will not be including specifics on how I did things here, but I will answer smaller questions. If you too are working on a VF500 you may want to see my other thread where I've been back and forth asking questions to the forum on how to solve problems with my build.
My motorcycle is a 1984 VF500F. I picked it up with 56,000km on it. I have been restoring it inside and out. I am replacing parts that I think are outdated, for the purpose of either making it look better or preform better. Besides bolstering the performance I am changing the look of the bike from it's boxy-retro look, and into a bit of a streetfighter or cafe-racer. One thing you will notice about this build is that it is not going to be a perfect show-bike finish. The simple answer to this is the fact that I can not afford the tools or materials, nor do I have the expertise to do it anyways. This bike is ultra-low budget.
Wheels
I sanded down the old paint and metal. I fitted modern radial tires that give it a lower profile (and in my opinion a cleaner look). Then I painted the red and white using Duplicolor wheel spray paint.
Seat
Being vertically challenged, I reshaped the foam of the seat while I was recovering it with new vinyl.
Handlebars/Mirrors
I pulled the cores out of the stock handlebars so that I can fit bar-end mirrors. Used a drill, tap and a slide hammer. Mirrors are in the mail.
Carburetors
After cleaning the carbs I put bigger jets in to accommodate a straight pipe and K&N air filter. I also did a mod that Dutchy taught me about where you drill an additional fuel line, to prevent a lean mixture on the fourth and third carb.
Fourth carb with jets and extra fuel-in^
