Carb walkthrough vs repair manual. 83 750
9 posts Started 23 Mar 2017 Last recovered post 24 Mar 2017 Wayback Machine snapshot 30 Jun 2017
Hey guys, I have a question about cleaning the carburetors on my 83. On the manual wish you would see in a  picture below, manual shows the front two cylinders are #2 and 4 which i agree with on the walkthrough posted on anther topic.
When you reference the picture posted in the walk through it does not match the manual as far as which cylinders are number two and four respectively. This may be confusing, only because I am confused at the moment, but please see the pictures below and notice I engraved the caps with the cylinder number and advise if I have the correct order.
Thank you
Ps the first picture of of my service manual.
The second is my cleaned carbs
The third is the designated locations for each carb as per the walkthrough
[image: 20170323_184306.jpg]
[image: 20170323_184422.jpg]
[image: imageproxy.jpg]
[image: 14903096619251446653086.jpg]
The image below is from the Honda service manual. Just the same as the Clymer manual.
[image: VF750.jpg]
Ok. So is it safe to assume the write-up for v45 in another thread has the wrong carbs labeled.
I mean worst case is I have to flip the springs around but still
Someone correct me if I'm wrong......The CYLINDER number has to do with firing order and engine repairs. The CARB number is a reference for which carb is the base carb for synching, and if there is a specific order in which to synchronize them.
Oh, those are the cylinder locations... Not the front/back locations for the carbs themselves?
I'm back to being confused :/
Looking at your pictures it looks like yours are numbered correctly.
The bottom picture does look incorrect, if it is the same set of carbs facing the same direction.
On the VF series, from a seated position:
Front left is #2
Front right is #4
Rear left is #1
Rear right is #3
On the carbrail #4 is the one carb where the throttle cables attaches to. That #4 is the carb where all the other carbs have to be synched to...
Thank you gentleman. Maybe I'll write up a year specific carb clean for the next guy.. If i set the wrong float height or something and need to redo it
End of thread · 9 posts recovered Wayback Machine snapshot 30 Jun 2017
