My clutch master is leaking badly and the brake is exhibiting signs of future trouble. New masters are cheaper than a rebuild kit. I can find 16mm m/c's easily. The factory sizes are 14 mm for the clutch and 16 mm for the brake. What will happen if I run the 16 mm on the clutch side?
I wouldn't buy any "new" m/c that was less than a rebuild kit.
If you go to Partzilla, and look up the part number for the clutch master piston kit, that will show you all the other bikes that take the same part, and so have the same diameter MC. There's a lot of them. Then get a used MC that looks the same as your old one off eBay.
I've never heard of a 16mm master cylinder on a modern Honda--at least not labeled as such. There are: 1/2", 14mm, 5/8", 11/16" and 3/4". Maybe on older models?
The window is cracked from time. No lever so can't test piston. Good shape housing. Unknown if window is replaceable. Free! Shipping will be pretty cheap. I'll take some pics tomorrow in daylight.
I would tear down your present master and try to determine why it's leaking. Rebuilding them is not at all difficult. The cheap Chinese replacements on eBay are sketchy. I'd rather spend a little more and rebuild the OEM one if the bore isn't worn out.
mordantly, 4/9/2017 at 10:43 PM
The windows weren't designed to be replaced, but they can be. I have replaced at least a couple dozen of these now. I stock mineral glass windows that can be used to replace the original yellowed, bulging, and cracked ones. PM me if you want the details.
I rebuild these regularly on the '86-87 VFR. $30 K&S (maybe K&L) kit, new window, clean/lube the lever mechanism. Tomk1960 (above) does a nice job on the paint, etc. I also have replacement glass, though not sure of the VF500 size.
Joe in IL
V4Dreams.com
End of thread · 14 posts recoveredWayback Machine snapshot 7 Jun 2017
