Vibration issues..
5 posts Started 28 May 2017 Last recovered post 3 Jun 2017 Wayback Machine snapshot 6 Jun 2017
Hi all
I have seen somewhere that someone had a problem with vibration which resulted in selling..
I have struggled with the same problem for a long time which I have finally resolved!!!
I discovered that one of the oxygen sensors was fouled which caused cylinder 1&2 to run leaner than 3&4 !! Also check & clean the reed valves! ! This also causes throttle response issues.. silky smoothe now!!!!!!!
How many miles on your VFR and how did you determine the O2 sensor was fouled?
I had a slight vibration for many miles, got worse recently, so started checking sparkplugs ignition coils, injectors finally took out o2 sensors for inspection, the front one was oil fouled seems for a very long time.. decided to replace rather than try & clean.. too much work taking out radiator twice.. was relieved to to experience the smoothness & power !! Dct gearchanges are surprisingly smooth now.. I susspect it was cause d by oil overfill.. my experience is to rather not fill the oil to the top line but round 75%..
i ALWAYS measure my oil when refilling....3.2 liters....it normally sits just above half way in the sight glass
Half way is good .. I now wait long period for oil to run down before finalizing the fill. Interesting that you find it to be half way with precise measurement.. heard some people found it on the line or a tad over..
End of thread · 5 posts recovered Wayback Machine snapshot 6 Jun 2017
