Clean up rusty pitted forks - sort of...
5 posts Started 2 Aug 2017 Last recovered post 9 Aug 2017 Wayback Machine snapshot 27 Feb 2020
Hello everyone,
This is is a quick how-to for those with crappy rusted forks. It's not a cure-all but might help reduce the amount of pitting and help your seals last a bit longer. The only ways to ultimately tackle rusty forks is to re-chrome or replace. This is just a temporary fix and doesn't work on heavy corrosion
You will need:
1. Cola (any brand as long as it has Phosphoric acid in the ingredients)
2. Piece of aluminium foil
3. Protective oil of your choice (I use ACF50)
Method is very simple: splash some cola on the forks and swish it about so it gets into the rust. Apply some cola on to foil sheet also. Now rub the soaked foil across the rust until it is completely removed.
You can actually feel the rust reducing as you rub. Go gently to avoid scratching the chrome - it works just as well gently. Best to rub left-to-right as this will create microscopic ridges for fork oil to dwell and protect the fork (same principal as honing a cylinder for piston rings). Up and down would create microscopic tears in the seal's mating surface, shortening its life.
In reality it it doesn't really matter  which way you rub - just go gently.
When you're satisfied simply wipe off the cola and apply some sort of lube protectant.
Lots of rumours on the internet suggest the phosphoric acid "converts" rust and the tinfoil chemically fuses bits of itself to the pitted area. I'm not a chemist and cannot confirm-or-deny this but I feel there is not enough Phosphoric acid in cola for this.
My my gut feeling is that the tin is harder than rust but softer than chrome. It removes the former without harming the latter. But the acid and chemistry might help things along. It creates a grey residue which might suggest the acid is working.
The only thing I know for sure is it works well.
You can can see from the pics how much of an improvement there was, although some deeper pits remain, although  they are much smoother and kinder to the seals.
One old-timer told me he seals the pits with flexible superglue and builds them up to match the surrounding surfaces. Normal superglue it too brittle. Sounds like a good idea but really time consuming.
This is process took less than 5 minutes and cost less than half a pound.
Hope it helps someone out.
Best,
stray
[image: IMG_4177.JPG]
[image: IMG_4296.JPG]
[image: IMG_4297.JPG]
[image: IMG_4298.JPG]
[image: IMG_4299.JPG]
You can actually use just water, and save yourself the sticky residue. Next time, try it before the cola method and see if it's as good.
Just water? I'll try that next time - thanks. Just goes to show the phosphoric acid does nothing.
Firgot to say in the last pic the left fork is still rusty whereas the right one has been cleaned. It's not perfect but you can see an appreciable improvement.
S100 polishing soap plus elbow grease does a fairly good job on that stuff.
Thanks MD
End of thread · 5 posts recovered Wayback Machine snapshot 27 Feb 2020
