No, a fella in Baltimore started the conversion, but at least he saved 99% of the stock bits. I got a groovy Ducati 900SS half fairing thrown in also. These bikes, as I said, share almost all of their DNA with the mighty LeMans, in fact the frame is identical. A good example of a Mk I LeMans will cost you way north of 10,000 bucks. So people got to taking an SP1000 and cutting it up and putting LeMans bodywork on them and now we have a ton of LeMans clones. BUT......
The SP1000 was designed in a wind tunnel and is 1000cc as apposed to the LeMans 850cc. In fact, the Mark II looked very similar to the SP. It isnt faster, because LeMans had bigger valves, higher compression and gigantic pumper carbs, but an SP is less busy and is described as "Long Legged". An added benefit is that following the carving up of all the SPs, they are now, unintentionally getting rare, especially with all the stock stuff on it.
One can turn any ol Tonti frame Guzzi into a cafe bike, but I wanted the mighty SP. The riders compartment is cocooned in an envelope of still air, while the V-twin rumbles along. It is so fun. Also, in case anyone is alarmed at the rotors, they are cast iron Brembo and they rust overnight, and it is part of the design.
The linked brakes: When you pull the brake lever, you get the right front rotor. When You hit the pedal, you get the front left rotor and the rear rotor. Sounds wacky, but when you use both front and rear together it stops rapidly. This example also had stainless lines already fitted, so boom. It also has unobtainium BUB exhaust, Koni shocks, SP-NT footrest hangers, groovy Metzelers, and electronic ignition. I added the period correct Krauser bags, the fork boots and the solo seat. Nothing is cut, and the stock seat can go back on with 4 bolts.
[image: 23519110_10214936906275880_3905250264611777027_n.jpg]
