I.D. This Ignition Switch?
8 posts Started 13 Mar 2018 Last recovered post 18 Mar 2018 Wayback Machine snapshot 22 Mar 2018
I have this Honda ignition switch in my stash and would like to offer it on fleabay but I don't actually know its application. I do know it's not for an '86-87 VFR. No part number on it. Anyone recognize it? Anyone need it?
Thanks, JOE in IL
[image: IMG_4366 2.jpg]
[image: IMG_4368 2.jpg]
[image: IMG_4369.JPG]
Looks like the one I just used on my 1000r
I have a working spare and a parts ignition for my first gen V4's, both have 6 pin connectors. My key codes are C37 and C96 respectively.
I noticed yours has a 5 pin connector and key code C06. I tried to reference which bike model used that code, but came up empty.
Physically, my switches look the same as yours, as has every switch for a mid eighties Honda I've ever seen. So, I guess you would have to find which models used a 5 pin connector.
[image: DSCF3284.JPG]
[image: DSCF3285.JPG]
You are correct, I just looked at the wiring diagram in the back of my service manual and the 1000r is 6 wires, do you know if the cap with the writing will come off with out damage?
So there's no "Park" function.   I can't think of a single one of my 80's bikes that doesn't have that.  Is that the 6th wire?
KAWGRN, ‎3‎/‎16‎/‎2018 at 5:25 AM
Yes. Undo the metal clamp on the wires and pop the cap off. Its only held in place by 3 indents. You can then clean the contacts and dielectric grease the unit.
Captain 80s, ‎3‎/‎16‎/‎2018 at 6:31 AM
Both my R's, Vf1100S, Vf750F, VF700F have "Park" settings on the ignition.
My 86 VF500F does not. It is a 5 pin connector as pictured. So I guess you are correct that the 6th wire is for that function.
FWIW the key code for my VF500F is A10.
[image: DSCF3286.JPG]
My original 86 has park (and all of my 500s).  Looks like your ignition was replaced at one point.
20 hours ago, Captain 80s
You are correct. A quick check of the wiring loom shows the other half of the connector is 6 pin.
So apparently a 5 pin will work as I had no issues with starting, lights, etc. Just no parking light option.
End of thread · 8 posts recovered Wayback Machine snapshot 22 Mar 2018
