Power Commander V and Auto Tune install
5 posts Started 28 Mar 2018 Last recovered post 16 Apr 2018 Wayback Machine snapshot 21 Nov 2018
Has anyone installed a PCV and Auto Tune on the 1200 yet? I'm curious if I need to weld a bung hole for the O2 sensor, or if I could remove the stock ones installed and use them instead. I'm not too sure if there's a size difference, hence why I'm asking.
Obviously it would be great if I could use the already existing hole. I don't feel like going to a muffler joint to have someone cut one for me.
you need to weld a new one  on the right position
elfreako, 3/28/2018 at 10:39 AM
I had two done on my 5 Gen catless headers so I could use the auto tune feature of my Rapid Bike module. It cost me $40 for two bungs to be put on. Although it would depend on where the bungs need to go, as the headers I brought in were off the bike, I’d imagine it wouldn’t be too painful for them to do.
Found this on the Power Commander website: http://www.powercommander.com/powercommander/products/AutoTune/powercommander_autotune.aspx
"  To use these kits your exhaust must have an 18mm bung installed "
And came across the following from the service manual, which I'm hoping should be accurate and fit. All I would need to do would be to close up one of the holes once fitted.
[image: Capture1.JPG.dd4101470a392d085d530a9f76590879.JPG][image: Capture.JPG.e615ecf6b38b0616b13a9dc840d55a68.JPG]
I think the OEM sensors are located in the two collectors, so using one of those positions would not give you readings from the whole engine.  That's usually the case, anyway.
End of thread · 5 posts recovered Wayback Machine snapshot 21 Nov 2018
