New to me, 2002 VFR800
1 posts Started 14 Sep 2018 Last recovered post 14 Sep 2018 Wayback Machine snapshot 22 Feb 2019
NodakVFR, 9/8/2018 at 3:13 PM
I believe I found the problem to charging system.  Just a guess, but it looks a little "crispy" to me.   :blink:
I've changed the R/R already, and now I'm trying that "pull-a-plug" from one side to the other technique I saw at SumSum '18!
Never a Carver around when ya need one!   :wink:
[image: 20180908_125953.jpg]
You need to test it. Just because it has discoloration doesn’t mean It’s bad
test each phase to ground and look for no continuity. Test each phase to one another, you need continuity here. Test voltage at idle and at higher RPM’s. Should see around 20V at idle and 60V at 7000 RPM. Here is mine, which tested well. And works well still.
[image: D55FEAE3-521A-48D0-8749-99BE5C16FAF0.jpeg]
End of thread · 1 posts recovered Wayback Machine snapshot 22 Feb 2019
