Lowering the 1200?
14 posts Started 8 Feb 2019 Last recovered post 11 Feb 2019 Wayback Machine snapshot 22 Aug 2019
I'd like to bring the rear down an inch or so.   How can this be done?
As an aside, it's going in for the recall shaft replacement within a week or two.
What's a purpose of lowering?
Rear shock could be solution, maybe..
Sent from my EVA-L09 using Tapatalk
srdjan, ‎2‎/‎8‎/‎2019 at 4:11 AM
Reach to the ground.  I can't back it even on level concrete
maybe you bought a bike that's too big for you ??
1 hour ago, squirrelman
Hell yes I did.  Always do.
Any other kind observations?
UpArrow,
On the off chance that you are not aware of it, if you install lowering links, it might be harder to use the centerstand,  depending on the amount of lowering of course.
LookingHard
2 hours ago, LookingHard
UpArrow,
LookingHard
Yeah.  Not looking to drop it more than about 1".   Center stand would be tougher but doable.
Consider OEM Lower narrow seat
19 minutes ago, srdjan
Wish I could try one.   I'm leery of spending $200 for the try.  That said, my bike came to me with a heated Corbin on it which I suspect is quite a bit taller than the OEM low narrow.
I have bought Top Sellerie dual gel seat. It is very comfortable but it is more width and taller as well, less sporty movements on bike. I am going back to OEM for sure. Those are FAQs on my bike. And I am 187cm tall :)
Low seat and run a 190/50 instead of the 55.  I suspect that would get you over an inch.
Don't 190/50, it will have negative influence as on almost every bike
End of thread · 14 posts recovered Wayback Machine snapshot 22 Aug 2019
