Background:
I have had a vibration issue with my bike for awhile, which occured suddenly after a full hot summers day of running my beloved VFR around a gocart track for a whole day at top speed. After that I rode it home on the highway and noticed engine vibrations that started at around 5.5k rpm and continued all the way up to the redline. I may have described the issue elsewhere here, or possible there (points at some other forum). I've gone through the usual suspects, like compression, drive chain, engine mounts, starter valves and injectors, but nothing have cured the problem.
Current affairs:
I had a list of further things to check this winter to get rid of the problem, but had to order tools to get to it. Well, after doing my second hot compression test (I need to be sure after all) I thought I could prepare myself for the next step (HEI testing, with my new tool that will arrive shortly) when everything already was taken out of the engine, so I placed one of my current spark plugs into the ignition coil and lo and behold it fell right out again. Hmm, that can't be right, can it? Tried with one old spark plug I had lying around since my change (I changed spark plugs well before the background gocart run) and that trusty old NGK plug stuck inside the coil as a very warm sweaty hand in a goretex glove. I have checked what I could regarding the ignition, like signal levels to all ignition coils. I also have had no problem at all with jerky idle, it runs smooth as a babys butt at 1250 rpm (I do have very well performing starter valves after several syncs...).
Proceeding to check out the plug I took out of the bike. The plug is marked Denso IUH27. It was sold to me by Partzilla, as a replacement spark plug for a 2002 VTEC VFR. I double checked the part number at the time with Denso, and they said it would fit my bike. I checked it again tonight, and now Denso says that it fits a VFR from 2000-2001, ie a 5th gen bike.
The spark plugs are almost identical, but the 5th gen version is slightly thinner at the ceramic part. Another thing I noticed when closely examining the two different spark plug is that the Denso plugs have a noticeable bigger gap, even though they are supposed to be identical. Probably slightly worse quality control by Denso, I don't know. Or maybe my high rpm misfires (if the vibrations are misfires) have done bad things to the plugs, but they don't appear to be worn? There are no carbon traces on the Denso plugs and no miscoloration of the tips either, they look pristine.
I haven't concluded that they are the culprit, but new spark plugs are in the mail. Thanks to Brexit the pound is lower so I ordered these new NGK's from the UK instead of the US. I'll report back if there's interest.
What is the consensus here, are the plugs likely culprits? I hope so, I'm slightly tired of chasing these illusive vibrations.
