So, my centerstand had a goodly bit of rust on it. And it was just generally fugly. Side stand was better, but the paint was well worn, so I thought I'd paint them while I had the exhaust off and could pull that centerstand easily.
And I will note that, yes, I was foolish not to take a before pic. But I'm sure you can imagine.
The results will come in a few days. But I started prep work this evening. I pulled the stands, used a water based stripper (but strong, it ate gloves so I had to get different ones right quick!) to strip the paint. Then wire wheeled it to get most of the paint off:
[image: centerstand1.jpg][image: centerstand2.jpg]
Did the same for the sidestand, which was a LOT easier. Way less convluted:
[image: sidestand2.jpg]
[image: sidestand3.jpg]
I actually did more than these pics, but I ran out of light.
From there it was to the sink to get the crud out of those smaller crannies. Simple green and a toothbrush, then some scrubbing with Barkeeper's Friend made them SUPER shiny. But these are decidedly NOT stainless steel parts. They're very stainy. It's like cleaning up a cast iron pan, the instant you strip it it starts rusting again. These pics are after about an hour:
[image: rps20190422_211744_525.jpg]
[image: rps20190422_211712_152.jpg]
[image: rps20190422_211835_670.jpg]
This is common. I've powdercoated cast parts for old motorcycles (Vincents and a 60s Triumph) and the same happens there. What I do is get 'em clean, dry them immediately, and get that primer or powder on right away. Like 15 minutes or less, right away.
Up tomorrow: I'll finish cleaning them (there's still some crud in the end of the centerstand) then spray them with primer. I'm not powdercoating as the centerstand is too big for my oven, so I'm going to try some 2K in a can. This is new to me, it'll be an adventure.
