1984 VF1000F
1 posts Started 8 Sep 2019 Last recovered post 8 Sep 2019 Wayback Machine snapshot 19 Sep 2019
~38,000 miles (still using it). I'm the 3rd owner. I'm in NJ and can reasonably help with delivery.   $2,300 Obro   Pretty nice mostly original bike, with some great upgrades. The paint is in VG condition and the decals are bright. I really like riding the bike a lot, but I have another one [image: :lol3]   The bad news first:   1) it's been making a loudish tricking noise from one of the heads for about 3,000 miles. It looks like the hardening/finish has come off the #1 exhaust cam lobe. Still runs fine- just need to turn the music up louder lol. 2) The other thing is that the left fork seal has started leaking and will need replacing. Bummer is that they were replaced 2 years ago when the forks were powdercoated. The pricing reflects that.     Lots of good news [image: :D]   - Hagon shock, - reasonably newly rebuilt and powdercoated front forks, brake calipers, master cylinders, handlebars and levers - SS brake and clutch lines - V4 Spark Boxes http://www.v4spark.com/ - newish (June 2019) EK Black chain and JT sprockets - Case Savers - Oxford heated grips - throttle lock - LED headlight - Power outlet in the cockpit - headlight on-off switch - manual fan switch - fuel pump relay bypass switch - voltmeter - 2 RAM mounts, a single and a double - VRR and battery replaced last year - valve check/adjust and radiator flush/refill done late summer last year.   The bike has a couple of cosmetic issues- the PO stored the bike in a way that resulted in a couple of gas tank and fairing dings. Not too obvious, but worth pointing out ahead of time. One other thing is that at some point in time, the starter button failed, so the PO (a helicopter mechanic) installed a push button & relay in the cover that's over the fuses. This is where I added the headlight and fan switches.   It's a very nice bike that's been stone reliable for the almost 10,000 miles I've had it. The only failure I've had was a VRR (duh, its a Honda V4 [image: :lol3])  and I replaced it with a Rick's unit. The bike now shows 14.1 V at idle with lights and heated grips on, and 13.9V with those on and a Gerbings liner and gloves plugged in & on.   Lot of value here for the money: especially if you can do the repairs.     [image: 20190403_180211-XL.jpg]     [image: 20190403_180221-XL.jpg]     [image: 20190403_180101-XL.jpg]     [image: 20190403_175953-XL.jpg]     [image: 20190417_175902-XL.jpg]   [image: 20190403_180036-XL.jpg]         More pics on request   Alternatively. I mentioned I have another one. That's a 15,000 mile 1 owner bike that I've been slowly getting back on the road. It's essentially a duplicate setup to this one: with the major difference being a a brand new WP shock and (planned) cartridge emulators in the forks. All bodywork has been freshly painted and I have a new decal set. Needs maybe a day or two to complete (basically forks and assembly of the front brakes. Will also need tires. I would be fine selling that one and fixing/keeping the one with the cam/lifter problem. I'd want $3,000 for that one as it sits.
End of thread · 1 posts recovered Wayback Machine snapshot 19 Sep 2019
