FOX TWIN CLICKER MOUNTING
9 posts Started 11 Sep 2019 Last recovered post 24 Sep 2019 Wayback Machine snapshot 14 Dec 2019
  Hi all , I own a 1987 VFR700F2 , I have just finished installing my Fox twin clicker . Only problem is I can not find a suitable place or way to mount the reservoir . It appears to be designed to exit & mount on the left side of bike ( left while sitting on it ) .
   If any of you have done this to your bike ? Any description ,explanation  or pictures of your way of doing this would be of GREAT help to me !!!
THANK YOU !
WHY ARE YOU SHOUTING IN RED?
Somewhere I may even have a copy of the original installation instructions! The reservoir was separated from the frame spar on some rubber mounts, and held in place with big hose clamps.
[image: vfr750f18.jpg]
     Was not aware I was shouting ? Thought shouting was when one used all caps ? Like you did . Is using colored font also considered shouting ? If so , I was not aware .
Mine is mounted in the same location as the picture above.
[image: Knipsel.thumb.JPG.d917005d1f693d3ef29502f9b75bfe9b.JPG]
As for the location of the clicker, any place will be fine, even under the saddle. You tend to set it once and forget.    But it it of course also a show piece!
For a while I had it here
[image: HPIM3869.thumb.JPG.e3e9c1c5bb169943a7daafcb16461579.JPG]
[image: HPIM3862.thumb.JPG.25167f61cb62f40587920db3cf9a6dde.JPG]
Ended up here:
[image: herfst2_zps8c5c12e1.thumb.jpg.47aac037988bcfb64bb57b0e4e5a5419.jpg]
6 hours ago, a1gatorz
I suspect you also copy/pasted this post from the other site?  He was mostly joking, but usual forum decorum dictates a reasonable color/font.
If you ever get your shock serviced, look into having a different hose installed that allows you to mount where you want.  My buddy has his mounted on the left grab bar (not where the engine and radiator heat exits the lower cowl) after having his serviced.
I modified the subframe on one of mine for a mounting location.  I knew I was not going to run passenger pegs.
[image: full?d=1497291619]
This is a Penske.  I had a Fox many years ago and it was probably mounted similarly.
[image: MVC009S-vi.jpg]
End of thread · 9 posts recovered Wayback Machine snapshot 14 Dec 2019
