Anybody had this happen before?
Ok so returned to the shop and somehow my speedo sensor was jammed onto the mount too hard, too far from the countershaft. Luckily they had a spare and got me on my way in 15 min!
Happens all the time with inexperienced mechanics. Did it myself once, not gonna lie.lol
They didn't need a new part likely, the plastic nut will slide on the shaft. Hopefully the dealer wasn't giving you the shaft!
Seems a little odd that they had such an obscure part for a 20 year old bike in stock... doesn't it?
it was used on about 30 bikes... soooo..
RDMcD Happens all the time with inexperienced mechanics. Did it myself once, not gonna lie.lol
Good to know they didn't charge you for the part. It was an error on the mechanics part though and totally preventable. Maybe he was having a bad day...it happens. If it worked when you went in it didn't go bad on its own though. If it ever happens again, a little pry with a screwdriver will slide the plastic nut back to its original position.
RDMcD Good to know they didn't charge you for the part. It was an error on the mechanics part though and totally preventable. Maybe he was having a bad day...it happens. If it worked when you went in it didn't go bad on its own though. If it ever happens again, a little pry with a screwdriver will slide the plastic nut back to its original position.
A correct speedo is vital on a road trip like yours........ :tour:
In 2012 on my TMAC trip (on Gradus' Vtec) I spend a few days prior to explore some of the south and visit Skuuter. Riding with gutted exhausts I was carefull in towns and long and behold I spotted a police cruiser's nose behind a billboard. Blues Brothers anyone? :goofy:
Sure enough he started tailing me and I made SURE I was stickng to the posted speed limit which varied as I rode along. He did follow me till the county line.
I could just imaging the questions (assuming I could understand him)
So you are a foreigner?
So you are not the owner of this ve hik el?
So you donot have do cu men ted proof you are allowed to use it?
So why were you exceeding the posted linit?
Better be safe than.....
It doesn’t hurt to replace it. They do wear out.
If you got another used one it may still be pretty worn.
[image: 4E6DB54A-0145-402A-AEA8-D84E1E29CD38.jpeg]
[image: E3BC5504-E87F-4785-B349-9DABD6807AA5.jpeg]
