Rectifier on 2000 vfr 800
6 posts Started 6 Oct 2019 Last recovered post 8 Oct 2019 Wayback Machine snapshot 23 Sep 2020
Is there a simple fix to this problem so i can just buy and change before something happens . Theres topic  everywhere but cant tell what to get
Check your stator too so you only have to take the fairings off once [emoji6]
Sent from my SM-N950U using Tapatalk
4 hours ago, Booboo
Hi ok I'll jump in ...
First what is the mileage on your bike and do you have a multimeter?
Next... follow the drill and dont half assed it, gimme numbers...
Then, its worth it to get a FH020aa for the 5th gen and install from there.
Based on your stator data whether to get a new stator or not....
22 hours ago, mello dude
Hello, bike has 20k on it and voltage is fine. I just figured id change before anything happens.  Should i just monitor the voltage and if its goes high than change.  Thank you
2 hours ago, Booboo
Best thing to do would be to install a digital voltmeter up front so you can watch the trend of what is going on.
Lots of great ideas in this thread.
End of thread · 6 posts recovered Wayback Machine snapshot 23 Sep 2020
