hi i know this will be covered a million times but here goes
1-1/2 year old yuasa battery died while out , i did leave grips switched on 🙄. luckily was in a hilly area so rolled and bump started it
recharged again overnight , ( no grips left now or other electricals ) showed 12.6 but didn’t go up while running .
mostly i commute to work or have an hour blast or so . commuting is only 8 miles or so and 15 mins so don’t know if it’s enough to get recharged
so i bought a motobatt heavy duty replacement and that reads 12.7 but again when running stays at that and not goes up to 13 etc as you. tube shows .
is the reg or stator on way out , if so where is best place to buy .
bike is 6 gen 2006 with 53000 and already came with the upgraded reg previous owner said ( he had bike from new ) . i’ve had bike 3 years and the yuasa replaced the yuasa that came with bike .
im in uk. so want quality parts . ebay is a minefield of cheap n cheerful regs .
i say so a lot 😂
tia
